How to Configure the Search Menu
About
The SearchMenu has the following features/functions:
Used to navigate between different SmartHub pages.
Disabled by default.
Available on the Index, Landing, and Results HTML pages
SearchMenu settings are found in the file DefaultModuleSettings.js, which is accessible from the UI Editor
Enable and modify the SearchMenu feature using the UI Editor
To customize the SearchMenu template, see the topic "How to Customize the Template," below
Customizing SearchMenu
UI Editor
To add/modify/remove a refiner the Results page, use the procedure below.
The optimal way to customize the search menu is via the SmartHub UI Editor.
For information about how to access the UI Editor as well as who can access it, see How to Use the UI Editor.
Procedure:
SmartHub administrators can simply click the UI Editor link from the SmartHub ADMINISTRATION page.
Select (double-click) the HTML page (Index, Results, Landing, etc.).
Below, the Index.html page is shown for sample purposes.
BA Insight recommends you create your own custom page and folder to modify. Leave the default files as templates.
Example: pages/index.html, shown below. Default Index.html is under the top most SmartHub directory.
See How to Create Custom Pages.
Select the Advanced mode from the top right of the page.
Select the Customize ContentContainers link from the top of the page.
Select the Advanced settings edit link at the top center of the page.
Scroll down to around line 169.
To access the available SearchMenu settings, click the See Default Settings link in the top right corner.
Search for the word "SearchMenu" on the page to quickly navigate to the SearchMenu settings, shown below:
Copy the SearchMenu settings section.
Go back to your Advanced settings edit tab.
Paste the copied settings inside the section SH.SearchMenu.CustomSettings.
Note the Template file referenced (line 789 in the image above)
To modify the SearchMenu template, see "How to Customize the Template, below"
Click Save changes.
Ensure SmartHub is loading your modified HTML file.
This is set in IIS for your SmartHub site under Default Document.
If your new custom page is not shown, click Add, and enter the relative path to your file.
General Options for the SearchMenu Module
| Option | Value | Description |
SearchMenuTemplate |
string Default: SH.RootLevelURL + "/modules/SearchMenu/SearchMenuTemplate.html" |
The path to the template used to render the menu |
ParentContainerSelector |
string Default: '#menu' |
The selector for the parent HTML element. |
Items |
array Default: { |
The list of menu items |
Options for the Menu Items
label |
string Default: "All".toLocaleString() |
The label of the menu item |
url |
string Default: "/Results.html" |
The URL where the menu item redirects at click |
iconClass |
string Default: 'fas fa-search' |
The CSS class for the menu item icon |
preserveQueryState |
boolean Default: false |
Setting it on true preserves the query text and custom attributes when switching menu tabs |
preserveRefiners |
Setting it on true preserves the applied refiners when switching menu tabs. PreserverQueryState also needs to be set to true. Note: This setting is incompatible with showTabCount=true The tab count will not take into account any presevered refiner. |
preserveQuerySource |
Setting it on true preserves the query source when switching tabs.
Note: This setting is incompatible with showTabCount=true The tab count will not take into account any presevered query source. |
showTabCount |
Setting it on true will show the result counts for the existing menu tabs. Note: This setting is incompatible with preserveRefiners=true Note: This setting is incompatible with preserveQuerySource=true |
queryTemplate |
string Default: '{searchboxquery} FederatorBackends:"*"' |
The query template used on the page specified at the URL setting |
querySourceId |
string Default: 'b29924a9-ec32-4c10-8892-a544b69ee121' |
The query source id used on the page specified at the URL setting |
expertiseConfig |
object
The expertise configuration if the page mentioned at the URL setting is an Expertise page.
Note: The count for the tabs that use Sharepoint Online backends will also contain the duplicate items.
Tip: If the admin configured the query template for a page to do XRANK (i.e. ({searchboxquery}) XRANK(cb=100) Author:Jim) the queryTemplate setting for the tab should not include the XRANK condition.
- Duplicate the out-of-the-box, template specified in the SearchMenuTemplate setting:
<SmartHub_install_dir>/modules/SearchMenu/SearchMenuTemplate.html
- Change the SearchMenuTemplate setting to point to the new template.
- Customize the copy created at step 1, making sure that the existing HTML structure is kept and the existing CSS classes are still used.
div class="megamenu">
<a href="javascript:void(0);" class="menu-header" onclick="SH.SearchMenu.toggleMenu()">
<div class="menu-header-wrapper">
<div class="menu-icon-wrapper">
<span class="menu-icon sh-icon-button">
<i class="fas fa-bars"></i>
</span>
<span class="menu-header-text" title="Menu">Menu</span>
</div>
</div>
</a>
<div class="menu-links" data-automation-id="searchMenuLinks">
for(var key =0; key < Items.length; key++){
var link = SH.SearchMenu.processUrl(Items[key]);
var label = Items[key].label;
var itemClass = SH.SearchMenu.isActiveTab(link.toLowerCase()) ? "active" : "";
var iconClass = Items[key].iconClass;
<a onclick="SH.SearchMenu.processItem(<%= key %>)" class="<%= itemClass %>" data-tab-index="<%= key %>" data-automation-id="searchMenuLink">
<span class="menu-icon <%= iconClass %>"></span>
<span><%= label %></span>
<% if(Items[key].showTabCount) {%>
<span class="menu-count">
<span class="loader hidden" data-automation-id="searchMenuLinksLoader"><i class="fas fa-sync-alt fa-spin"></i></span>
<span class="count">
<span class="count-value" data-automation-id="searchMenuLinksCountValue"></span>
</span>
</span>
</a>
</div>
</div>
